“Hinge plate offset from side” is incorrectly using the “Hinge distance from side” value as the plate’s distance from the door edge. (for blind corner hinges)
There’s an issue with the blind corner hinge plates. The “Hinge plate offset from side” prompt is tied to a lookup table value that only references the hinge distance from the side (22.5), and the system then applies this in the opposite direction to position the plate. It only works by coincidence because the Blum hinge cup offset happens to be within 1–2 mm of that value. When a different hinge brand is selected with a different plate position, the current setup fails. I realise you can override the hinge cup position using @ followed by a value, but that method doesn’t work for the plates.
