I just changed the edge banding on all my doors and drawer fronts to 3mm pvc. I just discovered that when doing that, the edge banding is changed for these parts in every spec group even if the spec group has a different material file. I thought maybe it was just a glitch when I copied and renamed a spec group it would hold onto the original setting, but that is not the case. All material edge banding is changed within every spec group, not just the copied one. I have several material files within all of my spec groups. Edgebanding is the same on all of them, even if I didn't change it. Anyone else notice this?
Maybe this is a issue with other builds as well. Just noticed it now.
