35mm Router
I have obtained a 35mm tool that we want to use in a tool holder as opposed to in the drill block to route our hinge cup pockets with.  At the machine this tool will be set up as a router with the function set to drill vertical blind holes since its essentially a drill.  My question is how would i set this up in Microvellum?  Would i set it up as drill, give the router number from the machine, check the Router option in the tool database, and then change the tool number in the machining tokens for the hinges?
I hope this is clear and understandable.
