A few questions for countertop products
Hi There,
I am in process of building a corian countertops library and encounter following questions and hopeful someone can help with.
  1. Pline Machining token-- How to turn it on and off based on the product prompts. e.g. For the "Route a Circle" machining token, I can just just set the radius to 0 when i want to turn it off.
  2. How to correct position of the baseline or turn it off. Right now it is not aligned with the product. See photo attached
  3. How do you guys deal with Sink Cutout. I am exploring two different approaches here. First it is to treat the sink as a hardware. But I have to create two hardware for the same sink so i can have  different machine tokens for both Corian Countertop and Subtop. Another way is to save those machine tokens and control location of it in the part property- machine token. Is there any advantage for one versus another?
Thanks in advance.
