The saw toolfile/processing station options don't allow the program generation to have any time of sort. You can do this with the reports, but that actually cause more confusion because now the programs for Biesse's OSI program as well as the programs/layouts in MV Production will not be in order of the paperwork.
For example, right now it seems to order the programs based on the material's name, but not size. So Basswood would come before Plywood, but 5x10 might come before 4x8 or not. What's worse is that it will likely mix them (I suspect based on the order it optimizes). So you may have the 1st program be a 4x8, the 2nd a 5x10, and the 3rd a 4x8.
