Currently Microvellum creates a compact database containing all the Work Order information when you create a Microvellum Work Order named "MicrovellumWorkOrder.sdf" in each Work Order folder. During this process, I would like the ability to add an ERP Project number and Work Order number to fields within the "MicrovellumWorkOrder.sdf" for the purpose of passing this ERP Project and Work Order Numbers along to a Material Handling System, lntelliStore for example. These numbers could then be passed along to an ERP system for job costing through an imported file. For example, INNERGY version 124 has the ability to import a file for Material Requests and Fulfillments. However, INNERGY requires that the INNERGY Project # and Work Order # be included to complete the Material Requests and Fulfillments. These can be manually added after the file is imported into INNERGY, but the process is more efficient if the ERP Project number and Work Order number are already included in the import file. By including these numbers, you don't need any additional manual adjustments.
