We use a nice 4mm wide led strip light from Hafele, problem is the current library setup is restricting us from being able to actually machine it. First of all the groove is only 4mm wide, which leads on to secondly id like to use the saw blade in the CNC to cut it, and not a router bit as it works perfectly for it and its 3x as quick. Thanks
