Add Rebuild Selected Products (& Subassemblies) From Library button to MV Palette
Modifying parts is a useful tool, but when editing the part shape, there's no easy way to revert it. Currently the user needs to open The Product List and select the product to rebuild from the library. This is also true for Subassemblies.
By adding the buttons Rebuild Products (or "Rebuild Cut Parts") and Rebuild Subassemblies from Library to the Parts and Subassemblies tab under "Modify", allows more work to be done directly in model space instead of opening the prompts and part properties.
