Adding a Lock - Need Help
I am adding a lock to the library and have hit a roadblock.  I have added the lock, and the associative drawing, but cannot get the orientation correct.  You can see from the attached picture that the locks need to rotate 90 degrees around both the x and z axis.  What am I missing?  Where is this controlled?  Is if from the original lock drawing or somewhere in the assembly?
Thank you.
