Adding Cut Parts to their own individual nested Blank
I am quite new to the more custom side of Microvellum, mostly just using standard library products and using the modifications that my company has set up, so apologies if the title isnt clear, or even leading to the correct topic.
My question for you all today is this.
Is there a way to put a Cut Part into its own Part Blank?
Assuming material is 19mm White Mel, and that all parts are cut on a Beam Saw prior to being machined.
So lets say I have a Cabinet Side that is 350mm W x 600mm L. Is there a way to nest that part into an oversized Blank thats 360mm W x 610mm L?
My first thought was to try and utilize MV's Perfect Graining, as it already puts parts into Blanks, but I would like to know if there is a better way or how I could modify PG to suit my needs.
Thanks, any help would be appreciated.
