Adding New Table to Global File Error
What would cause this error when adding a new table to the Global file?
v43.4 Metric (Customized) library.
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.Exception ---> System.ArgumentException: Invalid defined name 'LookUpTableNew' formula: "=''!$$537:$D$539".
   at ?.?.?(? A_0, ? A_1, Boolean A_2, ReferenceStyle A_3)
   at ?.?.?.?(String A_0, String A_1, ReferenceStyle A_2, ? A_3)
   at ?.?.?.?(String A_0, String A_1, ReferenceStyle A_2)
   at Microvellum.Common.Spreadsheet.clsWorkbook.set_DefinedName(String Name, String value)
   --- End of inner exception stack trace ---
   at Microvellum.BusinessManagement.Project.Globals.LookupTables.UI.DlgLookUpTables.?(Object A_0, EventArgs A_1)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
