How many of you have nested something only to realize you had one part that needed to be on a 5x10 instead of a 4x8. Or you viewed your nest results and discovered the one sheet of laminate in your nest only needs to be 4x8 not 5x12.
What if you could just add the sheet size to the work order? I am not saying let us adjust thicknesses since that would only cause problems. But adding a sheet size or changing available sheet qty should not cause a problem and would be very useful.
