Arc and Radius problem
Hi everyone,
I'm trying to do some arcs and radius to create a trim in a table and run them on a CNC. Those trims have different arcs and when I started copying the lines to create the angle, it looks like the arc ends are separated about 3/16" from the ends. (see attached dwg.). Does anybody have a solution on how to created them to touch the desired angle? the center looks like it does, but no the ends.
