Assembly holes for dado construction
Hi There,
How do you guys add pilot holes machining to dado construction. It comes with the holes when i have applied back but not on the captured back ( dado section). I looked over the Global file and have not found an answer. Is that something i have to add on through machining token?
Thank you
