I am trying to figure out if there is a way to rout machining in a specific sequence based on the tool used. I have a T-slot type cutter that I want to machine after a relief is routed with a straight bit. The relationship of the routs to each other wont allow me to create a multi-tool to do this. I don't want to have to manually assign the sequence in the nest, too much of a chance to forget and ruin a part and the tool.
