Assigning Materials to Layers before using SMA
Having trouble with SMA not recognizing materials that I've assigned to layers of my Autocad Model before analyzing.
Wondering if this feature been removed in the most recent patch? I've been using it for a few months now, but this is the first time since the update was installed and now its not working.
After selecting my model, SMA prompts me to select materials.
I believe the syntax is; "Layer Name_Material Name"
Where 'Material Name' must be written exactly as it appears in the material file.
I've checked the settings in Options under the SMA tab where Part Naming is checked to pull from Solid Layer.
What am I doing wrong?
Thanks
Peter H
