Associated products not moving with Wall
Anybody else noticing this? When using MVMOVE to move a wall the products associated to it used to move with the wall.
This isn't necessarily a problem because the products are indeed still associated and will produce sections when selecting the wall as normal. I just use the wall move thing to test and be sure products are associated to it. Is this a bug, was it left out in the last build for a reason?
