Back Dado
I am running into an issue with the back dado. I recently moved from MV 2019 to MV 2023. In 2019 the dado for the thick back almost looks like a pocket route. The bit selected will route in the shape of a rectangle. In 2023, the route is only a rabbet and not a route inside a rectangle.
I will post pictures below to illustrate. I have migrated the drilling and routing files to 2023 from 2019 and all routing selections are identical. The machining in the machining tokens tabs and all other machining options that I can find are identical down to the formula. Can anyone point out a reason or an idea on how to fix this?
I need the route from 2019 to be replicated in 2023. Thanks!
