I've come across an issue with the blind corner cabinet.
When set to a *Right Blind Corner with a blind facia and corner filler added, the machining only panel machine token for screws is adding edge drilling to the corner filler. (*Issue does not occur with Left Blind Corner)
Unfortunately, the Blind Panel & Corner Filler share the same Bay Position, which means adding a part filter to the machine token won't fix the problem as the parts are named the same. (Facia)
Machining Only Panel - Before
If the machining only panel was shifted to the carcass side of the blind panel and the machine token is amended, the problem is resolved.
Machining Only Panel - AfterI swapped the layer from MV FREEZE for visual representation of the issue and part in question.
