Blind Corner Hinge Plate Rotation Issue
I'm working with the Upper Blind Corner cabinet in the  Foundation Library Frameless Cabinets and there is an issue with Blum's Straight Hinge Plates. When I select Use Blind Corner Hinge option in the cabinet prompts, the hinge plate rotations on Y and Z are incorrect.
When I dig into the hardware settings, there is some logic which references Cabinet_Angle then again to the L!Transition.
I've attached screen shots. Anyone have a simple fix for this?
