Boring with Router bit
I am using the perforated panel and have setup a router to use as a vertical drill. Desired hole and Router size are the same (9/32"). When it is processed I get a notification that it has used the 1/4 router and will pocket the holes. Why not use the matching size router? Also, looking at the code, I see an offset command and things look correct.
When I plug the code into a NC viewer I see no offset (centerline) and that is proven at the machine resulting in a hole that is larger by the width of the cutter.
Am I missing something in my tooling setup or at the machine itself?
Thanks in advance.
