Breaking Composite/Laid-Up Material into Parts
Is there any way to separate a composite/laid-up material into the separate parts of the core material and the plastic laminates for each side when processing a work order?
For example, 0.6875MDF.000_Wht Liner_8844-WB would need to break down into a sheet of 0.6875MDF.000, a sheet of Whit Liner, and a sheet of 8844-WB plastic laminate.
I'm trying to generate a lay-up report that lists what the composite materials are (0.6875MDF.000_Wht Liner_8844-WB) and all the materials that need to be pulled from inventory (0.6875MDF.000, Whit Liner, and 8844-WB plam) to be sent to the press line for layup. This could possibly be used in the future to generate an import file for a Material Handling System for retrieving the core materials out of the Material Handling System.
If this isn't possible, I will work on generating the report from the .sdf file via other means. But, I wanted to ask first.
