This is a long post, but I wanted to get this out there while it may still be relevant as we wait for the 0915 Beta build to shake out. I started building out a custom library in Foundations months before BricsCAD was announced. We made the decision to get a heads start in moving away from the Component Cabinet library(50.7) as Foundation has become the new standard. We began using BSB with the new library at our sister company over six months ago. At the time I was still finishing up several large projects and hadn't transitioned over to BSB or the custom Foundation library I set up. I've now been in BSB for over two months now, and I must admit I wasn't prepared for all the challenges that have come with this transition, mostly related to the BricsCAD UI. Some things are certainly out of preference or old habits (AutoCAD 10+ years), but several are bugs or missing features.
Trying to juggle production while troubleshooting and then documenting all the issues or suggestions for improvements has proved more than I have time for right now. Many are not large enough of an issue on their own for putting in a ticket, but combined, they take up a great deal of time. Below is a laundry list of things that I've come across and I'm curious if any of them resonate with others and what solutions have been found:
BSB 2026
Foundation Library
Build: 26.1.803.641
BUGS:
1. FREQUENTLY HAVING ISSUE WHERE TRYING TO OPEN THE LAYER MANAGER DROP-DOWN MENU FROM THE RIBBON PANEL. HOVERING CURSOR OVER AND CLICKING ON THE DROP-DOWN DOES NOT ALWAYS WORK OR IS SOMETIMES JUST DELAYED. MOVING CURSOR AROUND RIBBON PANEL OR WAITING OCCASIONALLY HELPS. MANY TIMES I CAN CLICK THE DROP-DOWN ARROW SEVERAL TIMES WITH NO FUNCTION.
2. OVERDRIVE PRO UI WILL ONLY STRETCH WINDOW IN WIDTH, HEIGHT WILL NOT. (ONLY TESTED VIA SCREEN CONNECT 1080p GUEST & HOST – NO RESOLUTION SCALING)
3. FRACTION AUTOSTACK STILL DOES NOT FUNCTION WHEN TYPING OUT FRACTIONS. OEM WOULD STACK BUT WOULD NOT HONOR THE STACK STYLE BUT INSTEAD WOULD DEFAULT TO HORIZONTAL. BSB WILL NEITHER AUTOSTACK NOR HONOR THE CURRENT STACK PROPERTIES.
4. EVEN THOUGH DEFAULT DIMSTYLE IS SET TO "MOVE TEXT, ADD LEADER", DRAWDIM TOKENS ARE DRAWING WITH "KEEP DIM LINE WITH TEXT". THIS PREVENTS ADJUSTMENT TO THE LOCATION OF THE TEXT.
5. (SEE BEFORE/AFTER PHOTOS) LAYERS THAT ARE SET UP TO HAVE A DIFFERENT VIEWPORT COLOR THAN THE DEFAULT COLOR SOMETIMES DISPLAY THE VP COLOR IN MODEL SPACE AFTER WORKING INSIDE A VIEWPORT DISPLAYING THAT LAYER. FIXED WITH A REGEN. EXAMPLE: OUR TEMPLATE IS SET TO DISPLAY 2D_DIM AS RED IN MODEL SPACE AND BLACK IN THE VIEWPORTS. AFTER WORKING IN A VIEWPORT, WHEN SWITCHING BACK TO MODEL SPACE THE 2D_DIM IS DISPLAYING BLACK AS IF IT WAS IN A VIEWPORT. (REGEN FIXES IT)
6. (SEE PHOTO) LAYOUT TABS OCCASIONALLY WILL OVERLAP, FIXED WITH A RESTART. THIS ISSUE WAS PRESENT IN 2025 AND 2026 BSB.
7. LEGACY OPTIMIZER HAS QUIT FUNCTIONING; IT WILL BEGIN PROCESSING BUT NEVER FINISHED AFTER 30MIN FOR A VERY SMALL WORKORDER. HAD TO MAKE THE HARD SWITCH TO THE NEW OPTIMIZER.
8. (SEE PHOTO) NEW OPTIMIZER ROTATING RECTANGULAR PARTS FOR NO REASON, EVEN THOUGH IT DOES NOT IMPROVE YIELD. THIS WAS HAPPENING WHEN TOOLFILE WAS SET TO ADAPTIVE NESTING. I ASSUME THIS CAN HAPPEN SIMILARLY WITH TRUESHAPE ALSO.
9. WORK ORDER BATCH SELECTION WINDOW POPS UP AFTER CREATING A NEW WORK ORDER IN THE "WORK ORDER CREATION" UI. (THERE’S NO BATCHES LISTED IN IT SINCE IT’S A NEWLY CREATED WO)
MISC OBSERVED ISSUES:
1. (SEE PHOTO) LAYER MANAGER RIBBON PANEL IS TOO SMALL, DISPLAYS VERY LITTLE OF THE LAYER NAME.
2. LAYER MANAGER DROP-DOWN MENU SCROLL DPI IS VERY SLOW. IT TAKES SO MANY SCROLLS I NOW RELY ON DRAGGING THE SCROLL BAR.
3. WHEN ADDING A NEW FOLDER PATH TO THE LIBRARY PANEL(BRICSCAD TOOL), THE DEFAULT BRICSCAD LIBRARIES TURN BACK ON DESPITE HAVING PREVIOUSLY TURNED THEM OFF.
4. (SEE PHOTO) VIEWPORT LOOKFROM VIEW CUBE IS TRYING TO MAINTAIN ITS’ SIZE REGARDLESS OF THE ZOOM LEVEL IN PAPER SPACE. OFTEN TIMES IT BECOMES TOO LARGE AND COMPLETELY INTERFERES WITH WORKING IN THE VIEWPORT WHEN ZOOMED OUT FAR ENOUGH. WOULD CONSIDER A SETTING TO REDUCE THE SIZE OF THE VIEW CUBE IN VIEWPORTS SEPARATELY FROM MODEL SPACE OR A LIMIT ON HOW MUCH AREA IT CAN COVER INSIDE THE VIEWPORT BEFORE THE VIEW CUBE SCALES DOWN.
5. 2D PART EDITOR - WHEN UNDOING AN ADDED LEAD-IN OR LEAD-OUT: INSTEAD OF UNDOING THE ENTIRE LEAD-IN ACTION IT TAKES DOZENS OF UNDO'S BECAUSE IT MUST BE UNDOING ALL THE BACKGROUND LEVEL FUNCTIONS THAT ARE AUTOMATED IN THE COMMAND. USED TO BE ABLE TO QUICKLY CTRL+Z ONCE OR TWICE IF I NEEDED TO REVERT SOMETHING.
6. (PHOTO) NEW OPTIMIZER LAYOUT WHEN CUTTING A LOT OF LONG PARTS IS VERY RANDOMIZED, DOES NOT ALWAYS AFFECT YIELD BUT COULD NEGATIVELY AFFECT PART MOVEMENT AND JUST LOOKS “MESSY”. I HAVE CUSTOM PRODUCTS THAT ADD PARTS FOR POST LAMINATE. IT GETS RAN AS A NEST STRICTLY FOR GETTING A ROUGH LAYOUT AND ESTIMATING MATERIALS. HAVING THEM LOGICALLY ORGANIZED BY PART WIDTH ETC. IS NICE SINCE I SEND IT OUT THE SHOP SO THEY KNOW HOW TO BEST UTILIZE LOOSE LAMINATE WHEN CUTTING ON THE TABLE SAW.
SUGGESTED IMPROVEMENTS (MY WISHLIST):
1. GRIP EDITING IN 2D PARAMETRIC BLOCKS NOT AVAILABLE FOR VISIBILITY STATES WHICH MEANS I AM REQUIRED TO EDIT THE PARAMATERS VIA THE PROPERTIES PANEL - BOTH INEFFICIENT AND A TRAINING ISSUE WITH DRAFTERS WHO MIGHT BE UNAWARE OF A BLOCK’S VISIBLITY STATES.
2. WHEN CHANGING VISIBILITY STATES VIA THE PROPERTIES, THE DROP-DOWN MENU RE-SORTS THE V-STATES ALPHANUMERICALLY INSTEAD OF HONORING THE ORDER IN WHICH THEY ARE CREATED.
3. NO EXIT BUTTON FOR BLOCK EDITOR, ONLY "DISCARD CHANGES" DESPITE POSSIBLY JUST HAVING SAVED THE BLOCK. STILL WORKS TO EXIT THE BLOCK EDITOR BUT NOT INTUITIVE.
4. WHEN MODIFYING VISIBILITY STATE ENTITY NAMES, IT IS REQUIRED TO PRESS "ENTER" FOR THE MODIFIED NAME TO STICK. WOULD BE BETTER IF IT SAVE THE EDITED FIELD AFTER CLICKING OUT OF THE CELL.
5. WOULD LIKE AUTOHIDE FOR TOOL PANELS - IE PROPERTIES, LAYERS, LIBRARY, ETC.
6. ABILITY TO RESIZE TOOL PANELS SEPARATELY FROM EACH OTHER, CURRENTLY IF YOU OVERSIZE THE LAYERS PANEL THEN ALL THE OTHER PANELS SUCH AS PROPERTIES MATCH THAT SIZE.
7. WHEN EDITING PARAMETERS IN THE TOOL PANELS, ACCIDENTALLY MOVING THE CURSOR OUTSIDE THE BOUNDARIES OF THE CURRENT CELL AUTOMATICALLY DESELECTS THAT PARAMETER. (NOTE: THIS APPEARS TO BE A COMMON BEHAVIOR THRU-OUT BSB, ALSO OBSERVED THIS BEHAVIOR WHEN MODIFYING THE BATCH NAME FOR A NEW BATCH IN THE WORK ORDER PROCESSING UI.)
8. WHEN EDITING TABLES, I WOULD LIKE TO BE ABLE TO SELECT MULTIPLE ROWS BY DRAGGING ACROSS THE ROW NUMBERS. CURRENTLY YOU MUST DRAG A WINDOW SELECTION TO GET ALL THE CELLS, POTENTIALLY MISSING A COLUMN. ALSO, WOULD LIKE TO BE ABLE TO CTRL + A TO SELECT ALL CELLS IN A TABLE FOR THE SAME REASON.
9. FLOATING TOOLBARS FOR TEXT AND TABLE EDITING OFTEN GET IN THE WAY. WOULD PREFER THE MORE COMMON USE ACTIONS BE INCLUDED IN THE RIGHT-CLICK MENU SUCH AS ADDING OR DELETING A ROW. THE FLOATING TOOLBAR FOR TEXT FORMATTING THAT POPS UP WHEN EDIITNG INSIDE A TABLE FLOATS SLIGHTLY ABOVE THE ACTIVE CELL. WHEN WORKING IN LOWER ROWS, THIS TOOLBAR OBSCURES THE CELLS ABOVE, REQUIRING USER TO REPOSITION WHEN IT COVERS UP IMPORTANT CELLS.
10. WHEN PUBLISHING; DELETING LAYOUTS VIA THE RIGHT CLICK MENU IS PREFERRED OVER THE DELETE BUTTON IN THE FAR RIGHT OF THE UI.
11. ABILITY TO MOVE, COPY, AND DELETE MULTIPLE LAYOUTS FROM THE LAYOUT TABS INSTEAD OF HAVING TO NAVIGATE TO PAGE SETUP UI. (NOTE: I FINALLY DISCOVERED THE LAYOUT MANAGER MENU BY SELECTING THE HAMBURGER BUTTON JUST TO THE LEFT OF THE LAYOUT TAB. THIS HAS MOSTLY ADDRESSED MY GRIPES, BUT ISN’T AS QUICK AS THE AUTOCAD EQUIVALENT)
12. ABILITY TO DELETE FROM THE RIGHT-CLICK MENU VERSUS RELYING ON THE DELETE BUTTON TO DELETE LAYOUTS IN PAGE SETUP MENU.
13. LAYOUT PREVIEW WHEN HOVERING OVER THE LAYOUT TABS – A FEATURE PRESENT IN AUTOCAD. THIS ONE IS VERY USEFUL IN LARGER DRAWING SETS.
14. ABILITY TO SAVE DOCKED LOCATION FOR 2D PART EDITOR MENU, IT KEEPS OPENING UP IN FRONT OF MODEL SPACE, REQUIRING REDOCKING AND RESIZING EVERY TIME.
15. WHEN REASSIGNING A PART EDGE TO A MATERIAL POINTER VIA PART PROPERTIES OR EDIT DESIGN DATA, OPEN THE MATERIAL LIBRARY UI WITH THE LAST USED POINTER ALREADY SELECTED. THIS SAVES TIME WHEN ASSIGNING MULTIPLE EDGES TO THE SAME POINTER. AND THIS IS ALREADY THE BEHAVIOR WHEN DOING THE SAME FOR THE SHEET GOOD MATERIAL POINTERS.
16. I DON'T SEE ANY OPTION TO ALLOW NON-RECTANGULAR SCRAP. SCRAP SETTINGS IN NEW OPTIMIZER ARE ONLY ALLOWING RECTANGLES WHICH MEANS LONGER PIECES OFTEN NEEDED FOR SPECIALTY OR LOW INVENTORY MATERIALS GETTING CUT UP INTO SMALLER SCRAP PIECES.
