Buyout Doors in Reports
I'm encountering a problem, and couldn't find anyone else encountering the same:
When I use Project Properties to buyout all doors and drawer fronts it shows Buyout Drawer Override checked in Product Prompts and Subassembly Prompts. This seems correct
Next I create a work order and load the Door and Drawer Front Report. This seems correct.
Next I load Solid Stock by Width Report and it includes the buyout doors as material to be cut. This does not seem correct.
There is another option within the Subassembly Prompts called IsBuyout. When I check that and process Work Order the doors correctly don't show in the Solid Stock by Width, but they also don't show in the Door and Drawer Front Report. They also don't show in the Buyout tab of Modify Work Order.
Basically, have we broken something in making customizations to our Reports, or do your reports function the same way? I was looking in the Data Dictionary to find a prompt that I could filter out "buyout" parts from our Solid Stock by Width report and leave all of the rest of our functionality. Any suggestions?
Thank you.
