I am using the base cabinet products in MV - my actual laminated material is 0.81" thickness to I have updated the thickness in my material settings.
However, as soon as I do, all the dado & screw holes disappear for cabinet construction. When I change material thickness back to 0.75" they reappear correctly.
I suspect that my dado's are maybe set to a specific depth rather than tied to material thickness, but I'm not sure. And I can't figure out where to adjust those settings.
Anyone know how to easily correct this issue?
Thank you
