After customising a library cabinet, I have tried saving it back to the library - AU_Premium_Library_20_1_2 . Everything seems fine until I go to insert the new customised cabinet into a new Project. Some of the information that was set up reverts to something else.
Shown on the left in the attachment is the cabinet as designed with a DTC Pro drawer at the top and a Nikpol Bin with Smooth drawer runners at the bottom. There is also some machining for extra holes for the bin. The bottom and back for the drawer have been removed.
This was then saved back to the library.
The cabinet on the right was then inserted from the library. As you can see - the bin has disappeared and the drawer back and bottom have returned.
Is there something I am doing wrong when saving? Or is this normal?
Thanks,
Steve.
