Has anyone tried to set up a Sawing Optimization Report that could show what the minimum panel size required would be? Something that could incorporate the Leading & Trailing numbers in a material.
Or, can this even be accomplished?
Or, even in the Labels > Part Labels > MV Saw Labels > Show Patterns - while it shows the pattern layout, could show the min. L & min. W. that pattern would fit on.
