Change Default Name of Report
Is there a way to change the default name of a report dynamically when saving it as a PDF or other file format. I know that it can be programmed in the code of the report somehow but to date can't get it to work by changing the Me.ReportName = "Custom Name" Variable.
I know there is just a trick I am missing. Would make adhering to our naming conventions a lot easier and quicker.
