Change the Distance Between Parts functionality in the Processing station
Would it be possible to have the Distance Between Parts prompt in each the nesting processing stations changed to a distance to add to the nesting tool diameter instead of a fixed spacing? We occasionally select a tool with a larger diameter than our standard nesting tool by applying it to a material, but the spacing still comes out the same.
