Changing Base and Machine Points
I'm having issues getting our base corner floors to turn 90 degrees on our Pod and Rail CNC Machines. I have our current set up attached and everything appears to work except when the part is on the machine, it needs to be turned 90 degrees counter clockwise so the pie cutout is in the bottom left corner when it's on the machine, right now its in the top left corner. Is there an easy change to this? I've tried 15+ different Base/Machine point combinations and can't seem to figure it out.
