CNC Cut problem
After the CNC cut, there is a problem like I attached a photo below..
when first router cutting,  it cut around 0.5mm thick more..
and then after the second router cutting, it cut the correct dimension.. so I can see 0.5mm thickness left on the bottom of the board..
Is this the problem regarding the [ 0.5 thickness left for first nest pass ] ? please refer to the attached photo.
If not, Do you know why this cut problem happened?
