CNC Head Boring Optimization
Our machining department is asking if there is a setting to optimize the head boring within Microvellum?
For example, on a gable the CNC will drill one set of holes on the bottom of the gable then move to drill a set of holes on the top of the gable, then drill a set for the fixed shelf, etc, etc, etc.... The extra travel increases the machining time for all parts.  Can this be optimized within Microvellum?
We are running Biesse Rover machines with .cix files.  Biesse's bSolid has this as an optimization setting.
