Cnc Tools Stopping
Hi Microvellum.
Just wanted to know if anyone else has had the problem of a tool stopping before it proceeds to its first cutting operation. Since we installed foundation library it seems as though tool 7 on both our machines sometimes stops at the point it is about to go to its first cut. IE. All holes drilled in sheet ,now it will cut all 45deg finger pulls, the machine picks up the tool 7 drops down to it moving position and then stops instead of going to it start point and then cutting. this might happen 2 or 3 times then it works doesn't stop and the whole sheet is cut and sometimes doesn't happen at all just cuts the sheet no problem.
This is also showing up on 1 machine in that tool 2 our main perimeter tool has done some cutouts like power point/pipe holes and so on and then when it wants to go to cut out the actual pieces it returns to it travel height and stops.
Because this doesn't happen on all tools and on both machines I am reluctant to blame the program.
So any suggestions would be great.
Cheers Scott
