Hello,
I manually added spot holes using a .DXF on the side panels of a cabinet/microvellum product. I originally drew them in @ .125" DIA. I processed the Job then realized the Vertical drilling bit in the toolfile is @ .11811 (3mm).
So I went into the composite drawing and changed the DIA of all my spots holes to .11811
When I go to update existing gcode I recieve this error. Screen Shot of Error & Tool File.
Any Help would be appreciated Thanks!!
