Combine Face 5 and Face 6 Machining
Hello,
We would like to eliminate the need to flip parts/sheets by combining face 5 and face 6 machining when a thru cut exists. Is this possible?
For example, a thick back with mounting screw thru holes (face 5) and a manually placed wire channel (face 6)
For example, we have thick back with dado assembly, but the tongue is on face 6 requiring a manual flip and producing single part programs
We have set the material as 19mm White Melamine with always flip option on.
Please see attached.  Thank you
-James
