Copied Rooms Gives Errors
Does anyone else get errors with copied rooms in the same project as the original. I use the Copy Room command to make a copy of the room. The error I usually get is "Index was outside the bounds of the array."
I am using Microvellum 2019 with Build #21.0916.641.
