In my material file I can rename ( custom name ) sheet goods in the library and push them over to the left to update the project with those sheet goods . I cannot do the same with the hardware . If I rename my pulls to a custom name in the library and arrow over to the left the hardware report does not change and gives me what is coming from the wizard.
In this case I am trying to call out a custom wire pull by renaming a wire pull from the library that is of same size only . How do I get my custom name to read out on the hardware report as I do the sheet goods ?
