Creating report for a specific material only
Hi,
We would like to run a report where only parts to a selected material are processed, is this possible? It's required for a take off to a certain material in the project.
I can see in the processing center, you can load parts to the selected materials, but when the report is run, all parts to all materials are coming through.
We currently don't go straight to machine so at present we only process reports for the excel data it produces, if that has any bearing on why it might not be possible for us.
I know that we could create negative materials to omit them from the report, but this would require going into each room and changing materials to the relevant negative material which would take a lot of time to then have to change back again further down the line.
Thanks in advance.
