This is not a new problem but i'm trying to finally address. I dont know the root cause of it yet, but on either end of cabinets that need crown moulding, when they have side returns they are either too long on the left hand side but the mitre lines up, and doesn't touch the cabinet. So long overall. (1st screenshot) and in the second screenshot on a right hand return, the return isn't far enough out in the X and the front moulding is also too long in the X. I believe its to do with the panels and because my fix for them usually consists of adding or subtracting, 9mm and 18mm which is the same thickness as our panels. Thanks This is all based on a face frame cabinet as well.
