Hello,
I came across what I believe might be an issue today with custom dowel spacing on finished ends. From my digging, it looks the Foundation Library update 23.0623 added a new formula for to the dowel hardware tokens for cabinet bottom/stretcher/nailers and added additional columns to the global table "LookupTableCustomSpacedDowels".
Our default construction method is set to dowels with custom spacing and with this update, finished ends no longer receive correct dowel placements as it's now looking to the finished end columns of the global lookup table. I found I could resolve this issue by copying over the first few columns of that lookup table over to the finished end portion, essentially reverting it to how it was prior to the 23.0623 update.
I just wanted to bring this to attention here to see if anyone else has had this issue, in case this was an unintended bug of the 23.0623 library update or if something else might have caused this for us, and to check if my resolution would be considered safe to go ahead and make that library spec group change.
Thanks!
