Custom Label and Size
Does anyone have any insight on how id create a label that is 17 x 54mm, its sole purpose is to stick onto the back edge of shelves that are to be lipped. Our current workflow is nest it, machine it, label it, lip it, remove the label and mark write by hand on the back of it the customer initials and cabinet number it relates too then paint or finish it. Id like to remove the hand written part and have a label that is thinner than our thickest sheet so 17mm that can go on the back edge of the shelf to retain the customer and cabinet info. Its not so critical that the edge to be lipped wouldn't be in the right spot for the arrow so dont worry about that. Whatever edge is labelled then the opposite would be lipped or edged.
