Custom Subassembly takes multiple attempts to update any prompts
Hi,
Ive recently been working on a custom subassembly between projects, just a simple modified fixed shelf basically. For some reason all of a sudden now when i want to change any prompt in the subassembly, the first attempt will be completely undone, once i try to change the prompt again it will then work. This occurs whether using subassembly prompts or changing manually through part properties or design data. The only thing that changed from what i remember is that i started messing with an associative pline token.
This isnt a huge problem but a little frustrating, any help would be appreciated
