Cutout Token to allow path out of panel by desired amount
Hey,
We are trying to use the CUTOUT token to create grooves as it is a much easier and user friendly token to use, rather than using x2 ROUTE tokens or a PLINE token.
Obviously to create a proper groove through a panel, it has to be extended out of the panel by at least the radius of the cutter.
Problem we have with it is that when we look at the .mpr file, even though we have extended the cut out, out of the panel by say 20mm, the .mpr always shows it at 6mm.
No matter how much we extend the token out of the panel, it is always 6mm which is no good for any cutter with a radius greater than.
I've looked throughout the toolfile and processing station but cannot see where this setting s coming from.
Any one got any ideas?
Thanks in advance.
