Dado Gap
under library specifications group/global file/machining/dado machining settings & defaults/ dado depths & gaps :
is there a way to separate back dado depth gap from divider and stretcher depth gaps if you are using mortise and tenon construction method?
is only shows one option for dado gap and it affects every dado depth.
