Different materials for same pointer?
How can I have two different materials using the same pointer? The Base_Filler is set for plywood to match the door fronts when grain matching is required. However at "inner drawers with faces" the filler is spec'd for solid wood, but same pointer. How would others handle these different materials in the same room trying to use the same pointer?
