Dimension Leader
Hi,
We use annotative Dimensions for drawings and the text in all dimension styles is set to "Move Text, add Leader".
We find when we change the Drawing scale, this setting reverts back to "keep dim line with text".
We used blocks to add finish labels and text to our elevations and they must be added/redrawn at the scale the elevation viewport is at to show correctly. so when i need to move a leader in section (through the viewport or in model space and changing the scale so it shows correctly), if that viewport is at a different scale, all section dimensions change to "keep dim line with text"
In other words, the dimension style only adds the "move text, add leader" to the drawn/redrawn scale and not to any other scale in this annotative dimension
Does anyone have a suggestion on how to fix this or have we missed a setting with the annotative dimensions?
