FEATURE REQUEST - Correct Shelf Wide Span Calculation with Divisions
Products are no longer recalculating the Shelf Wide Span Width distance when a Division is selected. For example, a 36" wide base cabinet would use a 1" shelf because the Shelf Wide Span Width is set to 32". When a Division is added, one would expect the calculated span to be halved, thus allowing the use of a 3/4" shelf instead of a 1" shelf. However, the current configuration still references the wide value (1"), not adjusting for the reduced span.
Could this issue be addressed to ensure that shelf thickness is recalculated accurately when divisions are added? Additionally, it would be beneficial to review if other subassemblies have similar recalculation issues.
Thank you!
