Does changing reveals on doors change the space from door edge to center of hinge hole?
Recently I increased the reveals of doors in a cabinet to cabinet setting from 1/16" to 1/8". The program adjusted door sizes but didn't move the hinge cup bore. My question is, what is the standard practice? Moving the hinge cup bore, adjusting doors in the field or getting different hinge plates like a 3mm hinge plate?
Frameless cabinet construction
Imperial Component Cabinet Library
