Door/Front Options
I had an idea of making basic door cabinet products a bit easier & all in one. In product prompts having the options on a single product that allows you to pick left door, right door or double door. It would make changing cabinets easier without having to draw or replace with a whole new cabinet as well as reduce the product list a little. You could add other options too in prompts such as lift up & drop down doors to everything. So rather than having separate 1 door, 2 door, lift up, tall, base, wall etc... you would have a basic base, wall & tall door product that allows you to select an option of left door, right door, double door, lift up or drop down. Obviously you'd have unique products separate still, such as open or 3 door cabinets etc... I also had the idea for drawer units too, is it possible to have just a drawer unit product & then options in the prompts for how many drawers? so you could easily change a drawer unit from a 3 drawer base to a 5 drawer base in prompts rather than having a bunch of different products for each type of cabinet?
I dunno, this might be way too hard to achieve, but just a thought to try streamline work as well as cull some of the product list to make things easier.
