Double Passing Dadoes
It was brought to my attention that the dado's started doing double passing in the most recent builds.  I reverted back to Build 21.1.202.641 to see when this change was done.  Is there anything I can do to revert to single pass routes when the dado width is less than an inch?
  We use a 1/2" bit so double passing is not necessary unless the materials are thicker.  My operator is pretty good about making changes out on the machine if need be, due to a material thickness change.  Having these double pass routes adds more challenges.
